bootom maus sa pic 18f4550
kovacevic 2002
Post by kovacevic 2002 »
Pozdrav svima, dali bi mi neko pomogao naime radim u pbp-u, a nasao sam jedan cod za bootom maus napisan u programu C, posto nemam C compiler i nikada nisam radio u programu C dali bi mi neko iskompajlirao cod, i proverio ga daliu je dobar.Mis sa dugmicima mi treba za sina koji ide u graficku skolu, treba mu za crtanje, kupio bi ga, ali nema nigde da se kupi.
Unapred hvala evo coda:
// PIC18F4550 USB Mouse CCS C code
#include <18F4550.h>
#fuses  HSPLL PLL2 CPUDIV1 USBDIV VREGEN NOMCLR
#use delay(clock = 48000000)
#include <usb_desc_mouse.h>
#include<pic18_usb.h>
#include<usb.c>
#use fast_io(B)
char out_data[4];
void main(){
  setup_adc_ports(NO_ANALOGS);                          // Configure all AN pins as digital
  output_b(0);                                          // PORTB initial state
  set_tris_b(0x3F);                                     // Configure RB0 to RB5 as inputs
  port_b_pullups(TRUE);                                 // Enable PORTB pull-ups
  usb_init_cs();                                        // Initialize USB hardware
  delay_ms(1000);
  while(TRUE){
    usb_task();
    if(usb_enumerated()){                               // If the device has been enumerated by the PC
      while(!input(PIN_B0)){
        out_data[0] = 0;
        out_data[1] = 1;
        out_data[2] = 0;
        out_data[3] = 0;
        usb_put_packet(1,out_data,4,USB_DTS_TOGGLE);
      while(!input(PIN_B1)){
        out_data[0] = 0;
        out_data[1] = -1;
        out_data[2] = 0;
        out_data[3] = 0;
      while(!input(PIN_B2)){
        out_data[0] = 0;
        out_data[1] = 0;
        out_data[2] = 1;
        out_data[3] = 0;
      while(!input(PIN_B3)){
        out_data[0] = 0;
        out_data[1] = 0;
        out_data[2] = -1;
        out_data[3] = 0;
        usb_put_packet(1, out_data, 4, USB_DTS_TOGGLE);
      while(!input(PIN_B4)){
        out_data[0] = 1;
        out_data[1] = 0;
        out_data[2] = 0;
        out_data[3] = 0;
      while(!input(PIN_B5)){
        while(!input(PIN_B5));
        out_data[0] = 3;
        out_data[1] = 0;
        out_data[2] = 0;
        out_data[3] = 0;
        out_data[0] = 0;
        out_data[1] = 0;
        out_data[2] = 0;
        out_data[3] = 0;
SEMA
SEMA
kovacevic 2002
Re: bootom maus sa pic 18f4550
Jos bi bolje bilo ako bi mi neko ovaj kod iskucao u pbp-u jel pbp donekle znam pa bi mogao da usporim miš, ili da ga ubrzam.
Ja negde imam kod za tastaturu. Za misa sam isto imao ali ne mogu naci sad...
Vidi na picbasic.co.uk
kovacevic 2002
Pedja hvala na odgovoru, al nema gde nisam kopao i nigde nema a i engleski govorim dosta slabo pa mi je to problem, ima kod u pbp folderu, ali u kodu fali mnogo tog.Dali mozes ti pokusati naci kod, al treba mi da ima i dva tastera kao na misu.Unapred hvala.
kovacevic 2002
Evo koda koji sam nasao na ME Labs sajtu, ali tu nema definisanih tastera ...Uopste mi kod nije jasan jedino ako nepomera kursor u sve strane u tim petljama.
' Name        : USBMOUSE.pbp
' Compiler    : PICBASIC PRO Compiler 2.6
' Assembler   : MPASM
' Target PIC  : PIC18F4550 or similar type
' Hardware    : LAB-XUSB Experimenter Board
' Oscillator  : 20MHz external
' Keywords    : USBSERVICE, USBINIT, USBIN, USBOUT
' Description : PICBASIC PRO USB sample program for PIC18F4550 to
' move mouse cursor.
' Compilation of this program requires that specific support files be
' available in the source directory.  You may also need to modify the
' file USBDESC.ASM so that the proper descriptor files are included. For
' detailed information, see the file PBP\USB18\USB.TXT.
Define OSC 48
Include "hid_desc.bas"
buffer  Var Byte[4]
loopcnt Var Byte
state   Var Byte
   USBInit
   buffer[0] = 0
   buffer[1] = 0
   buffer[2] = 0
   buffer[3] = 0
movecursor:
   For state = 0 To 3       ' Move through each state
     For loopcnt = 1 To 16  ' 16 steps in each direction
       Branch state, [up, right, down, left]
up:
        buffer[1] = 0
        buffer[2] = -2
        Goto endgame
down:
        buffer[1] = 0
        buffer[2] = 2
        Goto endgame
left:
        buffer[1] = -2
        buffer[2] = 0
        Goto endgame
right:
        buffer[1] = 2
        buffer[2] = 0
endgame:
        USBService                    ' Must service USB regularly
        USBOut 1, buffer, 4, endgame  ' Send buffer to endpoint 1
     Next loopcnt
   Next state
   Goto movecursor      ' Do it forever
   End
Da bi ovo radilo trebaju ti i ostali fajlovi(usb descriptor).
Sto se tice dodavanja dugmeta, mozes samo staviti
if portb.0=0 then goto/gosub up
I tako definisati za svaki taster sta da radi. U prvih par tema ovde imas sve oko tastera objasnjeno.
