ATMEL 24c04 disassembly
mrworf
Post by mrworf »
Ovako, imam jedan mali prijenosni TV od 7", i malo sam ga išao otvarati i vidio da ima jedan mali ATMEL 24c04, imam i programator za njega i sve, a na internetu sam našao program za njega, i on služi u cijeloj prići za logo pri paljenju TV-a, našao sam isti program sa dva razlićita logoa i uspio sam promjeniti ih, ali ja želim stviti za logo svoje ime, a jedino što imam je .hex file koji sam uzeo iz samoga ćipa, dali je moguće iz gotovog hex koda dobiti nazad .c kod ili tako nešto da bi mogao ga promjeniti malo???
evo i kod:
:100000000011FF00000000000000000000000000E0
:1000100000000000000000000000000000000000E0
:10002000137BF605000016101E1F0C1D000002A514
:100030003F0050003F007F000000047F00321E5A46
:100040003F24082678AE7C505088A5E52626CACAEB
:100050000C0095130000000A4D1D5F1E320A30018E
:100060001050505080B2C205000000000100020094
:100070009D2B898CA61AB0A8943695269B779D381F
:100080009E189EF89FD7A197A618A709A8FDA618A5
:100090005348545257B1ABBF5798533057965FF1FE
:1000A0005D8446034260612C626D63B4650767DF5F
:1000B00045BF00000000000000000000000000003C
:1000C0000000000000000000000000000000000030
:1000D0000000000000000000000000000000000020
:1000E0000000000000000000000000000000000010
:1000F00000000000000000000000000200000000FE
:1001000000000000000000000000000000000000EF
:1001100000000000000000000000000000000000DF
:1001200000000000000000000000000000000000CF
:1001300000000000000000000000000000000000BF
:1001400000000000000000000000000000000000AF
:10015000000000000000000000000000000000009F
:10016000000000000000000000000000000000008F
:1001700000000000000000000000E7A7A7A7A7A755
:10018000A7A7A7A7A7A7A7A7A7A7A0A0A0B7A7B7F4
:10019000B7B7B737F7B7B7B7B7A1E77F0000000029
:1001A000000000000000000000000000000000004F
:1001B000000000000000000000000000000000003F
:1001C000000000000000000000000000000000002F
:1001D000000000000000000000000000000000001F
:1001E000000000000000000000000000000000000F
:1001F00000000000000000000000000000000000FF
:00000001FF
Hvala
Re: ATMEL 24c04 disassembly
Pretpostavljam da je u tom EEPROM-u obicna slika BMP ili nesto slicno, tako da C kod neces ni dobiti. Da li je taj logo crno-bijeli ili ima nijanse (monohromatski, http://en.wikipedia.org/wiki/Monochrome) ?
Probaj sam skontati koji je format unutra tako sto ces mijenjati bajt po bajt tog EEPROM-a i gledati sta se na ekranu ispisuje. Ne vidim drugi nacin...
mrworf
Post by mrworf »
hvala na odgovoru! Font je jednostavan i zeleni, nema nikakvih nijansi, izgleda mi rastegnuto preko ekrana pa se na prijelazima od npr. O vide pixeli, da mi izgleda ko neki BMP, odustao bih.... ali mislim da se ipak nešto može, idem baš, malo promjeniti jedan bit da vidim što će biti!
mrworf
Post by mrworf »
promjenio sam bit, i nema logoa više i slika je nekako na desno... :/
Pa vjerovatno si promjenio neki "kontrolni" bit... ili bajt.
Igraj se malo i skontaces...
mrworf
Post by mrworf »
Ma joj... Mrzim kad nešto ne mogu.... -.-
