Tiny GSM alarm
Sve vezano za mikrokontrolere
wlf2000
Re: Tiny GSM alarm
Post by wlf2000 »
[eDo] wrote:What version you make? SMD or DIP?
Dip Version with Pic16f84a.
I bought a PicKit2 and programmer the Pic, but i can't read because the Code Protection and i can't disable this option. its Possible?
The another problem: Where i connect 12v? in B.Bat ?
When i connect 12v( +(1º Pino) Gnd(5ºpino) ) the Led turn On, Turn Off and Turn On again. I put a button like you had in pictures, when i press the button nothing happens.
I problem with Pic? or sensor connect?
Re: Tiny GSM alarm
You probably didn't program the numbers in GSM phone correctly.
Follow the instructions on the project page!!!
http://www.elektronika.ba/666/tiny-gsm-alarm-system/" onclick="window.open(this.href);return false;
wlf2000
Re: Tiny GSM alarm
Post by wlf2000 »
trax wrote:You probably didn't program the numbers in GSM phone correctly.
Hello!!
I follow the instructions, and nothing Happens.
I plug sensors on 2nd and Grd pins. When sensos is close the led stay On and everything is normal.( I change To NO Sensores)
Another Question, on the siren's plug have 4.5V everytime :?
Thx for Help!
heli19
Re: Tiny GSM alarm
Post by heli19 »
bok
može li mi neko pojasniti kako se spoje žice u mobitelu i gdje
:P :P :P :P :P :P :
duga09
Re: Tiny GSM alarm
Post by duga09 »
pozdrav! Izradio sam ovaj alarm u DIP izvedbi sa 16f84A i siemensom S25...Alarm radi ali imam problem. Kada se aktivira uspostava poziva traje svega 2-3 sec i onda se poziv prekine.Ponovno pokušava i tako stalno ali ne uspije uspostaviti poziv na drugi mobitel. hvala!
bdragan
Re: Tiny GSM alarm
Post by bdragan »
Napravio sam DIP verziju sa 16f628 i kada uključim dioda stalno gori, znači ne trepne uopšte kako piše u uputstvu, mikrokontroler pali igasi telefon u zadatim intervalima vjerovatno nema komunikacije sa telefonom. Probao sam sa 2 C45 i MT50 bez ikakvih rezultata.
[eDo]
Re: Tiny GSM alarm
Post by [eDo] »
Slikaj shta si napravio. Jesi sam radio PCB ili si radio moju reviziju? Kod mene sa c35 radi 16F84 sam koristio...
bdragan
Re: Tiny GSM alarm
Post by bdragan »
Nema potrebe da slikam radio sam osnovnu verziju DIP. Ako imaš redizajniranu pošalji mi nacrt ako nije problem. Nisam probao sa 16f84 pošto imam verziju -04p pa ne znam da li će da radi na 10 MHz
[eDo]
Re: Tiny GSM alarm
Post by [eDo] »
Imenjache...
Slobodno ti isprogramiraj taj 04 hex-om za gsm alarm pa probaj. Vec je o tome diskotovano rade ti pic-evi i sa kristalom od 10Mhz bez problema ;) redizajn nisam radio ali moracu uskoro jer trebam raditi alarm za prijatelja u vikendici :)
primus
Re: Tiny GSM alarm
Post by primus »
Uh sve sklopljeno ali nešto ne štima
Kada se uređaj uključi upali se led, po pokretanju telefona se upali još jednom
Pozovem alarm radi aktivacije zazvoni jednom, prekine i ništa, led ostaje ugašena, ne reaguje na senzor.
Probao i hardver pin preko dip2, uz promenu rasporeda drugih dipova i opet ništa.
Kada ručno ugasim uređaj dugmetom upali se led, i nakon par sekundi alarm opet sam uključi telefon kako i treba da bude.
Raspored na dipu je ovaj G - gore D - dole
1 2 3 4 5 6 7 8
g d d g d d g d
Broj je upisan u SIM imenik onako kako izlazi na ekranu prilikom poziva, bez imena
Žice za napajanje su deblje, a ka rx tx pinu tanje 0,22mm2 od alarmnog kabla.
Nisam menjao onaj 0x01 kod u hexu, nije mi programator trenutno tu, videh da treba da se promeni samo ako ne dojavljuje pravilno.
Telefon je S35
Svaki savet dobro došao
Kad imaš čekić sve ti liči na ekser
primus
Re: Tiny GSM alarm
Post by primus »
Ma ovo ne radi nikako, promenio i hex adresu probao i m35i i sta sve nisam, dipove naucio napamet od silnog menjanja i opet nece. Jedino kada dobije poziv od alarma je kad se stavi callback dip na call inace ovako jok.
Niti se alarm stavi u naoruzano stanje tjs ne krene da blinka 3 puta kratko kad kada se naoruza pozivom
Mozda je do 628 verzije, kad narucujem delove uzecu 84 pa da probam
PicBeginer1
Re: Tiny GSM alarm
Post by PicBeginer1 »
Kod mene se mobitel ( Samsung M35) ne pali. U pojedinim trenutcima kad nešto "čeprkam" po pločici i žicama malo bljesne i to je to. Dioda se upali i gori 1-2 sekunde , onda se ugasi te se ponovo pali i trajno gori...
Ako možete pomoć, bio bih vam jako zahvalan .
Re: Tiny GSM alarm
Pa gledaj sta caprkas, mozda imas negdje loš kontakt!?
PicBeginer1
Re: Tiny GSM alarm
Pa gledam, evo recimo nekada znam da dodirnem micro kontroler i ono bljesne i još sam primijetio da mi se kontroler i previše grije ne znam dali to ima kakve veze. Isto tako kada žice kojima sam spajo pločicu sa telefonom pomijeram isto tako zna zabljesnut.. Instrumentom sam projverio i žice koje služe za napajanje , dole gdje je baterija, instrument pokazuje preko 9 volti.
Re: Tiny GSM alarm
Cini mi se da ti je mikrokontroler crkao. To mu se desi kada mu obrnes napajanje...
U sustini, nisi nesto dobro spojio na pocetku i sad je vjerovatno riknuo.
victor_u
Re: Tiny GSM alarm
Post by victor_u »
Hi
I did a dip version of 'Tiny gsm alarm' and use pic16f628a. I load the firmware file hex-firmware/firmware_22-11-2011/callalarmsys_PIC16F628A.HEX.
When I turn on the power to the circuit, LED lights up and does not go out.
What could be the problem? Tell me what to check.
Thanks.
Re: Tiny GSM alarm
What GSM phone did you connect?
Also, make sure you connected TX->RX and RX->TX and GND->GND between phone<->alarm.
victor_u
Re: Tiny GSM alarm
Post by victor_u »
trax wrote:What GSM phone did you connect?
I have connected Siemens A60. Also i tried to run without phone. Result the same.
I thought that the device was supposed to blink once if the phone is absent.
If the reason in the phone connection, I'll check the connection and report the results.
Re: Tiny GSM alarm
Check the connection. I never used A60... I hope it has AT modem inside :-)
victor_u
Re: Tiny GSM alarm
Post by victor_u »
trax wrote:Check the connection. I never used A60... I hope it has AT modem inside :-)
The problem was that I forgot to set the jumper on the common wire (Vss). :shock:
I fixed it, and now i have the next issue :)
Now, when I turn on the power, the LED blink once and several seconds off.
After that, LED lights up again and stays on.
A60 has AT modem, i checked it before via RS232<->TTL cable.
