Clean Hands in ARC Raiders turns a straightforward delivery into a test of route planning and restraint. While equipment preparation and ARC Raiders BluePrints may shape your loadout, this Frozen Trail quest is about reaching the right locations without taking unnecessary risks. On Pendola Pass, you must retrieve the Equatorial Sundial beneath the Railyard, place it atop the church tower in Old Town, and extract successfully.
Reach the Nomad Camp Beneath the Railyard
Your first destination is the Nomad Camp below the Railyard. The important approach is the pipe entrance between the Railyard and Transit Tunnel. Treat that connection as your navigation reference rather than searching every structure around the railway area.
Before entering, pause somewhere sheltered and check the immediate surroundings. Moving directly toward the entrance is preferable to lingering in exposed ground, but rushing into an occupied approach can create a fight you never needed. Listen, watch, and choose your moment.
Once inside the camp, prioritize finding the Equatorial Sundial. Optional supplies are secondary to the objective. After collecting it, confirm that the item is in your inventory before leaving; a quick check here is better than discovering a mistake at the church.
Carry the Sundial Without Inviting Trouble
The journey to Old Town is where discipline matters most. You now have something worth protecting, so avoid turning the trip into a general scavenging run. Extra stops increase your exposure and make it easier to lose track of your original route.
Choose cover over the shortest possible line whenever the direct approach looks busy. Keep enough resources available for the climb and the eventual exit. If you encounter other players, remember that completing the delivery is more valuable than pursuing an uncertain fight.
Handle inventory changes carefully while carrying the Sundial. Do not discard it during hurried sorting, and avoid unnecessary equipment swaps in exposed positions. If your route becomes unsafe, retreat to cover and reassess instead of forcing progress through a contested area.
Finish the Church Delivery and Leave Safely
Before approaching the church tower in Old Town, decide how you intend to extract afterward. Check your available exit options and think through the route from the church. The delivery point should not be the first place you start planning your departure.
Reach the top of the tower and complete the placement interaction. Confirm that the objective has updated before descending. Then leave with purpose rather than treating the successful delivery as permission to chase more supplies.
Clean Hands rewards a focused run: retrieve, deliver, and extract. Whether you are comparing cheap ARC Raiders BluePrints or preparing your own equipment, keep the mission route and a practical exit plan at the center of your preparation.
U4gm Arc Raiders Equatorial Sundial Location Guide
Benniehench03
