Program 1:
Očitavanje TUCH Memorija AVR-ovim čipom 1200
;*Includes*
.include "1200def.inc"
;* Pin Definitions*
.equ RxD =6
.equ TxD =0
.equ LED =2
;*Global Register Variables*
.def greska =r16
.def temp1 =r17
.def temp2 =r18
.def temp3 =r19
.def acca =r20
.def accb =r21
.def ZL =r30
.def ZH =r31
;* Interrupt Vectors*
rjmp RESET
;* FUNCTION
;* w30us (1+(1+2)*79+4=242=30.25us)
w30us:
ldi temp1,79 ;1~
tloop1: dec temp1 ;1~
brne tloop1 ;2~ 1+(1+2)*79+4=242=30.25us
ret ;4~
;* FUNCTION
;* w5us
w5us:
ldi temp1,12 ;1~
tloop2: dec temp1 ;1~
brne tloop2 ;2~ 1+(1+2)*13+4=242=5.5us
ret ;4~
;* FUNCTION
;* w480us
w480us:
ldi temp1,0x5
tl13: ldi temp2,0xff
tl12: dec temp2
brne tl12
dec temp1
brne tl13
ret
;* FUNCTION
;* w300us
w300us:
ldi temp1,0x4
tl23: ldi temp2,0xff
tl22: dec temp2
brne tl22
dec temp1
brne tl23
ret
;* FUNCTION
;* w200ms
w200ms: ldi temp3, 16 ;1~
tl3: ldi temp2, 0x82 ;1~
tl2: ldi temp1, 0xff ;1~
tl1: dec temp1 ;1~
brne tl1 ;2~
dec temp2 ;1~
brne tl2 ;2~
dec temp3 ;1~
brne tl3 ;2~
ret ;4~
;* FUNCTION
;* test
test: sbi PORTD,0 ; Tx =1
rcall w480us
cbi PORTD,0 ; Tx =0
rcall w30us
rcall w30us
rcall ima
ret
;* FUNCTION
;* ima
ima: in acca,pind
andi acca,0x40
brne l2
ldi greska,0x02
l2: rcall w480us
ret
;* FUNCTION
;* citanje
citanje:
rcall w_one
rcall w_one
rcall w_zero
rcall w_zero
rcall w_one
rcall w_one
rcall w_zero
rcall w_zero
ret
;* FUNCTION
;* w_one
w_one:
sbi portd,TxD
rcall w5us
cbi portd,TxD
rcall w60us
ret
;* FUNCTION
;* w_zero
w_zero:
sbi portd,TxD
rcall w60us
cbi portd,TxD
rcall w5us
ret
;* FUNCTION
;* w60us (1+(1+2)*160+4=125~=60.62us
w60us:
ldi temp1,160 ;1~
tl4: dec temp1 ;1~
brne tl4 ;2~
ret ;4~
;* FUNCTION
;* read_no
read_no:
clr ZH
ldi ZL,0x08
rl2: dec ZL
ldi temp3,0x08
clr acca
rl1: asr acca
andi acca,0x7f
sbi portd,TxD
nop
nop
nop
nop
cbi portd,TxD
rcall w5us
in accb,pind
lsl accb
andi accb,0x80
rcall w60us
add acca,accb
dec temp3
brne rl1
st Z,acca
cpi ZL,0x00
brne rl2
ret
;* FUNCTION
;* r_bit
EERead_seq:
in temp1,EEAR ;get address
inc temp1 ;increment address
out EEAR,temp1 ;output address
sbi EECR,EERE ;set EEPROM Read strobe
;This instruction takes 4 clock cycles since
;it halts the CPU for two clock cycles
sbi EECR,EERE ;set EEPROM Read strobe 2nd time
in temp2,EEDR ;get data
ret
;***** Copy 8 bytes of EEPROM to registers
copy:
out EEAR,accb ;EEAR <- $ff (start address - 1)
ldi ZL,8 ;Z-pointer points to r8
loop2: rcall EERead_seq ;get EEPROM data
st Z,temp2 ;store to SRAM
inc ZL
cpi ZL,16 ;reached the end?
brne loop2 ;if not, loop more
ret
;* FUNCTION
;* provera
provera:
ldi temp3,0x08
mov acca,r0
mov accb,r8
rcall lp1
mov acca,r1
mov accb,r9
rcall lp1
mov acca,r2
mov accb,r10
rcall lp1
mov acca,r3
mov accb,r11
rcall lp1
mov acca,r4
mov accb,r12
rcall lp1
mov acca,r5
mov accb,r13
rcall lp1
mov acca,r6
mov accb,r14
rcall lp1
mov acca,r7
mov accb,r15
rcall lp1
ret
lp1: cpse acca,accb
ret
dec temp3
breq lp2
lp3: ret
lp2: ldi greska,0x08
rjmp lp3
; beep Tonski signal, LED i rele
beep:
sbi portd,LED
ldi acca,0x07
bl2: ldi temp3,0xff
bl1: sbi portd,1
rcall w300us
cbi portd,1
rcall w300us
dec temp3
brne bl1
dec acca
brne bl2
clr greska
cbi portd,LED
ret
RESET:
main:
clr greska
ldi temp1,0xff
out ddrb,temp1
sbi DDRD,2
sbi DDRD,1
sbi DDRD,0
l6: rcall test
andi greska,0x02
breq l6
rcall citanje
rcall read_no
ldi accb,0xff
rcall copy
rcall provera
andi greska,0x08
breq ll1
rcall beep
ll1: ldi accb,0x07
rcall copy
rcall provera
andi greska,0x08
breq ll2
rcall beep
ll2: rjmp main
program
program
kako ovo upisati kojim progijem upisati
AVR Studio 4, potrazi na
www.atmel.com
www.atmel.com
buco
buco
generiran izvorni kod nekim od crosscompilera iz visih prog jezika , znaci nije pisan izvorno u assembleru !
Posto mu ne treba 12V imas ICprog ili pony programtor preko paralelnog porta . Oko 5 linija koristit i par otpornika !
Shemu samog spajanja MCU pinova imas u svakoj dokumentaciji o MCUu [ Atmel je to dobro napravio] !
Ja te stare sheme nemam vise u ovom compu , malo googlaj i naci ces 100% nesto jednostavno s otpornicima na LPTu.
