Hall senzor, smjer i broj okretaja
majstor1
Re: Hall senzor, smjer i broj okretaja
Post by majstor1 »
Pozdrav,
jučer sam imao nekih problema sa porukama na forumu, te mi je admin to riješio. Kako sam obrisao određene poruke, evo kod koji sada djelomično radi. Na ulazu (RB0 i RB1) su PULL-down otpornici 10K. Kod povećava broj okretaje za jedan, ali kada krenem u kontra smjeru, kod počinje smanjivati za jedan, a onda nenadano poveća broj za jedan, pa opet oduzima (ne postoji pravilo u njegovom ponašanju). Imam osjećaj kao da interrupt rutina ne stigne obraditi bitove i da zakasni.
program Dva_senzora_1703
' PIC18F4550 -  8 MHZ
' EasyPic5 MicroBasic PRO
dim hall_sensor_0 as sbit at RB0_bit
dim hall_sensor_1 as sbit at RB1_bit
dim hall_sensor_direction as sbit at TRISB0_bit
dim hall_sensor_direction_1 as sbit at TRISB1_bit
dim count as word
dim count_str as string [5]
dim broj as byte
dim LCD_RS as sbit  at RD4_bit
    LCD_EN as sbit  at RD5_bit
    LCD_D4 as sbit  at RD0_bit
    LCD_D5 as sbit  at RD1_bit
    LCD_D6 as sbit  at RD2_bit
    LCD_D7 as sbit  at RD3_bit
    LCD_RS_Direction as sbit at TRISD4_bit
    LCD_EN_Direction as sbit at TRISD5_bit
    LCD_D4_Direction as sbit at TRISD0_bit
    LCD_D5_Direction as sbit at TRISD1_bit
    LCD_D6_Direction as sbit at TRISD2_bit
    LCD_D7_Direction as sbit at TRISD3_bit
sub procedure interrupt
  If Testbit (INTCON2,INTEDG0=1) and (INT0IF_BIT = 1) then
         if TestBit (Intcon2,INTEDG1=0) and  (INT1IF_bit=1)  then
             GIE_bit=0
             inc(count)
             INT0IF_bit = 0
             INT1IF_bit=0
             GIE_bit=1
          end if
      else
         If Testbit (INTCON2,INTEDG1=1) and (INT1IF_BIT = 1) then
           if TestBit (Intcon2,INTEDG0=0) and (INT0IF_bit=1)  then
               GIE_bit=0
               dec(count)
               INT1IF_bit = 0
               INT0IF_bit=0
               GIE_bit=1
              end if
         end if
     end if
End sub
main:
  ADCON1 = 0x0F
  trisa=0 trisb=1
  porta=0 portb=0
  Lcd_Init() Lcd_Cmd(_LCD_CLEAR) Lcd_Cmd(_LCD_CURSOR_OFF)
  hall_sensor_direction=1
  hall_sensor_direction_1=1
  count=50
'--------INTERRUPT Setup----------
  RCON.IPEN=1                ' kada je ipen=1
  INTCON.GIE=1                      'global int on
  INTCON.PEIE=0                    'all int on
  INTCON2.RBIP=1                'možda ne treba jer se odnosi na b4-b7
  INTCON3.INT1IP=1               ' visoki prioritet
  INT0IE_bit = 1                 'int0 on
  INT1IE_bit = 1                 'int1 on
  INTCON.RBIE=0
  INTCON.RBIF=0
  INTCON.INT0IE=1
while true
  wordtostr (count, count_str)
  LCD_Out (1,10, count_str)
  LCD_Out (1,1, "Broj")
  PORTA.broj=$FF
  delay_ms (100)
  porta.broj=0
  inc (broj)
  if broj>4 then
    broj =0
  end if
wend
end.
majstor1
Post by majstor1 »
Pokušao sam sve prebaciti na RB4 i RB5 koristeći Interrupt on change. Nešto se opet s nečime sukobljuje. PIC je na momente blokiran (pinovi su "čisti"), a kada nešto radi samo zbraja ali čudna zbrajanja, kao da se u rutini zadržava dovoljno dugo i povećava varijablu count. O oduzimanju niti jednog minusa. :cry:
     iF tESTbIT (INTCON, RBIF=1) THEN
          IF (portb.4=1) and (portb.5=0) THEN
                inc (COUNT)
                temp = PORTB
              PORTB = temp
              INTCON.RBIF=0
              INTCON.RBIE=1
          ELSE
             IF (portb.5=1) AND (portb.4=0) THEN
                   DEC (COUNT)
                  temp = PORTB
                  PORTB = temp
                  INTCON.RBIF=0
                  INTCON.RBIE=1
             END IF
          END IF
     END IF
End sub
main:
  ADCON1 = 0x0F
  TRISA=0
  trisb.4=1
  trisb.5=1
  TRISD=0
  count=0
  TEMP=0
  INTCON.RBIE=1
  INTCON.RBIF=0
  INTCON2.RBPU=1
  BROJ=0
  PORTB=0
micromatic
Post by micromatic »
Pozdrav,
Nisam baš s PICevima na ti ali probao sam ovaj kod u Proteusu i radi OK.
Što se hardwera tiće važno je da su ti u jednom trenutku oba INT ulaza 0. (vidi ranije postove). Ako još nešto ne radi piši.
program Hall_1503_INT
dim count as word
dim Broj as word
dim Smjer_str  as string [4]
     If  INT0IF_BIT then
           if portb.1 then
              dec(count)
              Smjer_str="Dole"
           end if
           INT0IF_bit = 0
     end if
     If INT1IF_BIT  then
          if portb.0 then
             inc(count)
             Smjer_str="Gore"
          end if
          INT1IF_bit = 0
     end if
End sub
main:
  ADCON1 = 0x0F
  trisa=0 trisb=1
  porta=0 portb=0
  Lcd_Init()                     ' Initialize Lcd
  Lcd_Cmd(_LCD_CLEAR)            ' Clear display
  Lcd_Cmd(_LCD_CURSOR_OFF)       ' Cursor off
  count=0
  broj=0
  'RCON.IPEN=1                ' kada je ipen=1
  INTCON.INT0IE=1                  ' Enables the INT0 external interrupt
  intcon.INT0IF=0                  ' Clear IF
  INTCON.RBIE=0                    ' Disables the RB port change interrupt
  intcon.RBIF=0                    ' Clear IF
  INTCON2.INTEDG0=0                ' Interrupt on falling edge
  INTCON2.INTEDG1=0                ' Interrupt on falling edge
  INTCON3.INT1IE=1                 ' Enables the INT1 external interrupt
  intcon3.INT1IF=0                 ' Clear IF
while true
  LCD_Out (1,1, "Smjer ")
  LCD_Out (1,7, Smjer_str)
  LCD_Out (1,11, count_str)
    PORTA.broj=$FF
    delay_ms (100)
  porta.broj=0
  inc (broj)
  if broj>4 then
    broj =0
  end if
wend
end.
Da sad ne crtam nešto novo s onim "otvorenim optocouplerima" (senzorima) možeš izvesti nešto ovako ali tebi ne treba niz rupica već samo jedan otvor dovoljno velik da istovremeno oba senzora budu prosvijetljena.
__________________
http://www.micromatic.hr
__________________
Kukinjos
Post by Kukinjos »
Malo sam pogledao što si radio, i evo kod:
program HALL
' PIC18F4680 -  8 MHZ
' EasyPIC v7 MicroBasic PRO
dim hall_sensor_0 as sbit at RB4_bit
dim hall_sensor_1 as sbit at RB5_bit
dim hall_sensor_direction as sbit at TRISB4_bit
dim hall_sensor_direction_1 as sbit at TRISB5_bit
dim count as word
dim broj as byte
dim old_hall_sensor_0 as bit
dim LCD_RS as sbit  at RC4_bit
    LCD_EN as sbit  at RC5_bit
    LCD_D4 as sbit  at RC0_bit
    LCD_D5 as sbit  at RC1_bit
    LCD_D6 as sbit  at RC2_bit
    LCD_D7 as sbit  at RC3_bit
    LCD_RS_Direction as sbit at TRISC4_bit
    LCD_EN_Direction as sbit at TRISC5_bit
    LCD_D4_Direction as sbit at TRISC0_bit
    LCD_D5_Direction as sbit at TRISC1_bit
    LCD_D6_Direction as sbit at TRISC2_bit
    LCD_D7_Direction as sbit at TRISC3_bit
     INTCON.GIE=0                      'global int off
     If TestBit (INTCON, RBIF=1) THEN                                           'ako se dogodio int. on ch.
          IF (hall_sensor_0<>old_hall_sensor_0) and (hall_sensor_1=0) then      'provjeri je li se promijenilo stanje na senzoru A i je li senzor B=0
              IF (hall_sensor_0=1) THEN                                         'alo je A=1
                  inc (COUNT)                                                   'zbroji
              else                                                              'ako nije (A je dakle 0
                 dec (COUNT)                                                    'oduzmi
              END IF
           END IF
     END IF
     old_hall_sensor_0=hall_sensor_0                                            'postavi stanje sen. A u flag za detekciju promjene
     INTCON.RBIF=0                     'obrisati RBIF
     INTCON.RBIE=1                     'dopusti Int. on change
End sub
main:
  ADCON1 = 0x0F
  TRISA=0
  TRISC=0
  count=0
  INTCON.RBIE=1
  BROJ=0
 while true
  LCD_Cmd(_LCD_CLEAR)
  PORTA.broj=1
  delay_ms (100)
  porta.broj=0
  inc (broj)
  if broj>4 then
    broj =0
  end if
wend
end.
Nešto me zezao displej na portu D, pa sam ga prebacio na port C, nije mi se dalo istraživati. Senzore sam stavio na RB4 i RB5, a kako nisam imao tvoj kontroler, stavio sam nešto slično PIC18F4680. Meni na ploči radi odlično, ne gubi korake i ide brrrrrzo. Nadam se da sam barem malo pomogao
Post by bob4 »
Ako ne ide soft rješenje; evo hard .... :lol:
http://i.imgur.com/j0o3qrU.jpg
majstor1
Post by majstor1 »
Hvala svima na strpljenju i pomoći,
Kukinjos, isprobao sam tvoj kod, radi odlično. Odustao sam od svog koda, jer i dalje gubim korake.
majstor1
Post by majstor1 »
Pozdrav,
danas napokon isprobano na stroju i na moju žalost, brzina čitanja senzora nije dobra. Na 300 okreta moji senzori pogriješe do 35 okretaja.
U Inerrupt rutini je samo dio koji je Kukinjos predložio. Što bi mogao biti problem sporog očitavanja senzora?
Ima li tko kakvu ideju.
Pokušao bih sa hall senzorom, ali neznam koji da upotrijebim. Na osovini imam jedan magnet (okrugli oko 1 cm u promjeru). Možda bi sa njima to bilo bolje?
micromatic
Kojim senzorom si testirao to na stroju? (optički, magnetni ili hall)
__________________
__________________
majstor1
Post by majstor1 »
Pozdrav,
BNY 37, optički. Analizirajućislučaj, ustvrdio sam kako dođe do određenog "preskakanja" po jedan okretaj. Nema pravila kada se to dešava. Provjerit ću još jednom shemu spojeva, otpornike i sl.
Post by bob4 »
da nije CNY37 ?
http://mic.hit-karlsruhe.de/projekte/ad ... t_2000.pdf pogledaj malo vremena ulaznog signala....
majstor1
Post by majstor1 »
Da, moja greška to je CNY37.
Mislim da sam pronašao razlog. Drugi tjedan provjeravam na stroju pa ću napisati rezultat.
Na mom modelu stroja namotao sam 586 namotaja u 15-tak sekundi, a ručno sam odmotavao i brojao. Sve je bilo u redu. To je veća brzina okretanja nego na stroju gdje sam radio. Mislim da je problem u veličini otvora na disku (na osovini). Povećat ću dužinu otvora.
Post by bob4 »
Zato sam i rekao da provjeris vremena....najsigurniji je staviti prorez na pola kruga
majstor1
Post by majstor1 »
Pozdrav,
veći prorez (dužina kao tri senzora smještena jedan do drugog)i problem je riješen. Broji i pri najvećim brzinama. Još jednom hvala svima na pomoći.
