Config 1wire = P1.0
Config Lcd = 16 * 2
Config Lcdpin = Pin , Db4 = P1.4 , Db5 = P1.5 , Db6 = P1.6 , Db7 = P1.7 , E = P1.3 , Rs = P1.2
Declare Sub Citaj1820
Dim Temperatura As String * 6 , Temperatura_alarm As String * 6
Dim Bd(9) As Byte
Dim T As Single , T1 As Single , Tmp As Byte , Cc As Bit
Dim Pali As Single , His As Single , Plus As Single
Dim Broj_rada As Byte , Rad As Bit
S1 Alias P3.2
S2 Alias P3.3
S3 Alias P3.4
Pali = 23
His = 0.1
Plus = 0.2
P1.1 = 0
Cc = 0
Rad = 0
Broj_rada = 0
Do
Call Citaj1820
Temperatura = Fusing(t , ###.#)
Temperatura_alarm = Fusing(pali , ###.#)
Cls
Upperline
Lcd Temperatura_alarm ; Chr(0)
Locate 1 , 10
Lcd Chr(3) ; " " ; Temperatura ; Chr(0)
Lowerline
If Cc = 1 Then
Lcd "Noc"
End If
Locate 2 , 15
Lcd Broj_rada
Debounce S1 , 0 , Noc , Sub
Debounce S2 , 0 , Dodaj , Sub
Debounce S3 , 0 , Oduzmi , Sub
Loop
Sub Citaj1820
1wwrite &HCC : 1wwrite &H44 : Waitms 250 : Waitms 250 : 1wreset
1wwrite &HCC : 1wwrite &HBE
Bd(1) = 1wread(9) : 1wreset
Tmp = Bd(1) And 1
If Tmp = 1 Then
Decr Bd(1)
End If
T = Makeint(bd(1) , Bd(2))
T = T * 50
T = T - 25
T1 = Bd(8) - Bd(7)
T1 = T1 * 100
T1 = T1 / Bd(8)
T = T + T1
T = T / 100
' palenje bojlera
Dodaj:
Do
Pali = Pali + Plus
Gosub Prikaz
If S2 = 1 Then 'ako je tipka otpuštena
Return ' izađi iz sub
End If
Loop
Return
Oduzmi:
Pali = Pali - Plus
Gosub Prikaz
If S3 = 0 Then
Gosub Oduzmi
End If
Return
Prikaz:
Cls
Upperline
Lcd "Namjestanje temp"
Lowerline
Lcd "Radi od " ; Temperatura_alarm ; Chr(0)
Wait 1
Return
