SMPS 400v za napajanje lampi
suncica2222
Post by suncica2222 »
trebalo bi mi napajanje za lampe u audio pojacalu 50-100w
googlao sam dosta nasao sam jednu semu male snage za 12ax7 u pretpojacalu,regulise se 100-200V
na primer ova sema,nije mi jasno da li je ovo trafo ili samo spregnut kalem?
http://diyaudioprojects.com/Tubes/12AX7 ... ematic.jpg" onclick="window.open(this.href);return false;
meni treba nesto jace,takodje vrlo pozeljno bi bilo da moze da se trimerom regulise visina napona
ima li neko semu ili link od projekta?
Re: SMPS 400v za napajanje lampi
A koja je razlika?
To je u principu jedan kalem sa izvodom na 12stom namotaju, ili 2 namotaja od 12 i od 80 navojaka. I redno vezani. na isto dodje.
A jezgru pogledaj na netu...
suncica2222
http://www.siliconchip.com.au/cms/A_102096/article.html" onclick="window.open(this.href);return false;
evo na ovako nesto sam mislio,ovde je projekat,samo sto nigde nema link za semu,verovatno prodaju kit ili tako nesto
kad bih samo nasao semu od ovog projekta
halumori
Post by halumori »
Hey guys i need help to do a project on SMPS using switching regulator? I am doing a project on design and development of SMPS using switching regulator. A chip of the company Maxim is involved in this project. It comes in maxim 50X series but i dunno the exact chip model number. if anybody knows about this chip or have any information about this project as a whole pls help me out.
affiliateelite
On this address http://www.maxim-ic.com/products/power/dc_dc_switchers/" onclick="window.open(this.href);return false; you can find a lot of useful information. You can also click on the button 'Support' at this site for additional information.
Cale
Post by Cale »
imaš nešto ovdje
http://bas.elitesecurity.org/indexV.html" onclick="window.open(this.href);return false;
pa ovdje svega pomalo
http://sound.westhost.com/projects-4.htm" onclick="window.open(this.href);return false;
evo i ovdje
http://www.cadaudio.dk/pwmaudio_en.htm" onclick="window.open(this.href);return false;
suncica2222
hocu da uzmem ispravno ATX napajanje od 400V i na sekundar njegovog trafoa koji daje 12V da stavim primar mojeg kojeg cu ja namotati, sa sekundarima koji meni odgovaraju
meni trebaju naponi od 9,15,160 i 200V
moze li neko da mi kaze koliko namotaja mi trebaju za svaki namotaj?
postojeci trafo na ATX ima 1x12V ili 2x12V na sekundaru????
zelim da izbegnem srednje izvode, stavljao bih cele gretzove ne izlazu
koje brze diode (4 a ne 2) ili gretz mi preporucujete?
suncica2222
nitko?
kizbaja
Post by kizbaja »
ako vec motas trafo onda premotaj taj od atx-a
ako sam ja uspio bez problema dobit stabiliziranih 80V i ti ces 200V
i mozes ubacit dva trimera i s jednim regulirat napon od 0 do 200V, a sa drugim maximalni napon
ovdje ti je sve detaljno objasnjeno
suncica2222
hvala sad cu da pogledam,obecava link
suncica2222
ovde je bas detaljno trebace mi 2-3 sata da proucim ovo,svidja mi se
