Prodaja Elektronickih Dijelova sa slikama
Mezz
Post by Mezz »
BD249 POWER TRANSISTORS(25A,125W)
http://img145.imageshack.us/my.php?image=bd249nj1.jpg
BTA40-700B ST(SGS) 40A 700V Triac
http://img241.imageshack.us/my.php?imag ... 0b2by8.jpg
BUZ100 N-FET 50V 60A 250W
http://img184.imageshack.us/my.php?image=buz100qp0.jpg
BUZ21 N-MOS 100V 19A 75W i BD249C NPN 100V 25A 125W
http://img237.imageshack.us/my.php?imag ... 49cma5.jpg
BUZ31 N-channel MOSFET 13.5A 200V
http://img218.imageshack.us/my.php?image=buz31jj5.jpg
Dioda 300U40A(300A 400V)
http://img136.imageshack.us/my.php?imag ... 0a2xj6.jpg
5KP14 GPP transient voltage suppressor.5000W peak power,5.0W steady state
http://img81.imageshack.us/my.php?image ... p14fz4.jpg
Diode BYX97-300 (300V 40A)
http://img98.imageshack.us/my.php?image ... 300bx4.jpg
Dioda MR751 6A 100V Silicon Rectifier
http://img138.imageshack.us/my.php?imag ... 751pw9.jpg
Dioda DR63-400-12-1 (1200V 400A)
http://img136.imageshack.us/my.php?imag ... 121ub7.jpg
http://img401.imageshack.us/my.php?imag ... 212go9.jpg
Elektrolitski kondezatori 100000mF 63V i 47000 63V
http://img407.imageshack.us/my.php?imag ... torne8.jpg
Kristali od 1MHz do 93Mhz
http://img186.imageshack.us/my.php?imag ... alizz0.jpg
Mikseri (HPF-505,IE-500N,IE-500A, IE-500-4L,IE-800F,MCL SBL-1)
http://img72.imageshack.us/my.php?image=mikseri2pm0.jpg
Murata DFC2R902
http://img301.imageshack.us/my.php?imag ... 902tl2.jpg
Murata DFC3R94
http://img301.imageshack.us/my.php?imag ... r94kb6.jpg
Murata Keramicki Filteri CFM455
http://img100.imageshack.us/my.php?imag ... eriil2.jpg
Oscilatori od 12MHz do 67MHz
http://img136.imageshack.us/my.php?imag ... ri2kc9.jpg
Otpornici 15R 100W,1R 100W,2R2 100W, 1R5 50W,2R 50W,1R 50W
http://img403.imageshack.us/my.php?imag ... ci2bm3.jpg
Relej Hi G Italia
http://img155.imageshack.us/my.php?imag ... ia2sp4.jpg
http://img402.imageshack.us/my.php?imag ... ia3iw2.jpg
Relej Iskra PR59C
http://img157.imageshack.us/my.php?imag ... 59cpz4.jpg
http://img157.imageshack.us/my.php?imag ... 9c3lp4.jpg
Relej Iskra TRP6931
http://img228.imageshack.us/my.php?imag ... 931sd5.jpg
Relej Iskra TRM2903
http://img401.imageshack.us/my.php?imag ... 032gn4.jpg
Relej Iskra TRK1703
http://img401.imageshack.us/my.php?imag ... 032yt8.jpg
Relej SDS Relais NT1-6v
http://img166.imageshack.us/my.php?imag ... 6v2de1.jpg
Tiristor TR61-125-12-54(125A)
http://img171.imageshack.us/my.php?imag ... 254ek1.jpg
Trofazni Gretz SKD160/08(160A 800V)
http://img296.imageshack.us/my.php?imag ... 160vb2.jpg
http://img299.imageshack.us/my.php?imag ... 602mt9.jpg
Vrhovi za lemilo Weller
http://img296.imageshack.us/my.php?imag ... lerye8.jpg
Ventilatori 220V 31W i 220V 9W
http://img182.imageshack.us/my.php?imag ... ri2re2.jpg
Toyocom 21J4B
http://img178.imageshack.us/my.php?imag ... j4bcu8.jpg
Toyocom Oscilatori
http://img409.imageshack.us/my.php?imag ... oriav2.jpg
Sklopke
http://img299.imageshack.us/my.php?image=sklopkewf6.jpg
http://img47.imageshack.us/my.php?image=sklopke2lk0.jpg
Tranzistor STE180N10(N CHANNEL 100V 180A ISOTOP POWER MOSFET)
Minijaturni Releji A5W-K(slika,2 po redu)
SDS Releji(slika,3 po redu)
Delay Line(slika,4 po redu)
http://img115.imageshack.us/my.php?imag ... orimp7.jpg
IC krugovi(UA,TN,SN, MC,LM,ML,L, TFK,TDA,HM,MCM,HD,ICL,Z80,Z84, AM,HCF,BA, TCM,CD,HEF,MAB,CAT, SAB,PC,SG,MM,RM, CA,CIC,HA i ostali)
http://img145.imageshack.us/my.php?image=icml9.jpg
http://img172.imageshack.us/my.php?image=ic2df7.jpg
http://img294.imageshack.us/my.php?image=ic3op1.jpg
http://img166.imageshack.us/my.php?image=ic4dy5.jpg
Ugradbeni Instrumenti
http://img179.imageshack.us/my.php?imag ... ntiyu3.jpg
http://img161.imageshack.us/my.php?imag ... ti1kf2.jpg
http://img169.imageshack.us/my.php?imag ... ti3lh2.jpg
http://img161.imageshack.us/my.php?imag ... ti5xd2.jpg
http://img406.imageshack.us/my.php?imag ... ti7lj5.jpg
http://img406.imageshack.us/my.php?imag ... ti8oo6.jpg
Digitalni Ugradbeni Instrumenti
http://img59.imageshack.us/my.php?image ... entrp6.jpg
http://img116.imageshack.us/my.php?imag ... nt2kd1.jpg
Kleme za akumulator
http://img116.imageshack.us/my.php?imag ... tordd4.jpg
Kleme za aparat za varenje
http://img177.imageshack.us/my.php?imag ... njecn2.jpg
Motorola NLD 6642A(hibrid modul,tranzistor 35C05,slika)
http://img117.imageshack.us/my.php?imag ... ridih1.jpg
Osciloskop Philps GM5655
http://img49.imageshack.us/my.php?image ... op2cl2.jpg
Punjac Akumulatora(15A,sa regulacijom struje i strujnom zastitom)
http://img49.imageshack.us/my.php?image ... oraqz5.jpg
RC Generator Iskra MA3601
http://img403.imageshack.us/my.php?imag ... or2qh9.jpg
Dijelovi za laptop(procesor PII433MHz 128Kb cache,memorija SDRAM, modem,tpikovnica, zvucna kartica i cd-rom)
http://img128.imageshack.us/my.php?imag ... tophf5.jpg
http://img128.imageshack.us/my.php?imag ... op3yq9.jpg
http://img329.imageshack.us/my.php?imag ... op4yt9.jpg
http://img217.imageshack.us/my.php?imag ... op5xj0.jpg
Transformatori od 3,5A do 40A
Stabilizatori napona: 7809,7812CV,7912, 7912C,7912CV,7805CV,7815S, 7815CV,7824CV,7824, 7808, L4810CV
Varistori(S20K60,S14K14,S10K25,S20K40K, S20K250V,S20K300-470V,S20K150V, S14K25,S14K40K,S20K25, S14K20,S14K300)
Tiristori i Trijci(TR61,T911,TYN,KT,TAG,TIC,BTA,BRY)
Tranzistori(BD,IRFP,BF,IRF,TIP, BUT,2N,BUX,MJ,BDX, MRF,BFW,BFR,BFT,BFQ, BSD,BUZ,BDW,BU,SRF, 2SC,2SK,SGSD)
Pa eto koga zanima neka se javi na mail (mezzenga@net.hr) za detaljan katalog ili na broj mobitela +385 91 763 34 16, cijene su po dogovoru.
73 9a7plv Bruno
mirzza
Post by mirzza »
imas li TAG 17 tijak , SAB 0600 IC i kristal od 12 Mhz i koliko ih cjenis ako ih imas
Mezz
Post by Mezz »
Imam samo TAG064,imam sab3024,a kristal imam od 12MHz,znaci jedino ti odgovara kristala jel se to isplati slati? :)
mirzza
Post by mirzza »
hajde ako meni jos nesto bude trebalo ja cu se tebi javit pa da mi to posaljes 8)
Imas li trenutno HIGH POWER WHITE SMD LEDs ???
pocetnik
Post by pocetnik »
Ove Diode 300U40A(300A 400V). Nekako mi se cine premale za 300 A ali neka koliko ih cjenis?
Dariolo
Post by Dariolo »
imas li ista od ovog 2SD1718 ili 2SC3281 ili 2SD1975 ili 2SD2155
Mezz
Post by Mezz »
Sto se tice dioda pogledaj na internetu,a pogledaj i sliku mislim da je to moguce bez problema.koliko ih cijenim pa ako si zainteresiran dogovorit cemo se,ljudi smo:)
Sto se tice ovih tranzistora sto ih trazis dariolo nema nazalost takvih oznaka.
Uglavnom ako koga zanima detaljan katalog svega,a ima puno zanimljivih stvari neka se javi na mail:mezzenga@net.hr
Pozdrav,hvala
zmedak5
Post by zmedak5 »
disi ovo pokra jeba te :lol:
zmedak5 wrote:disi ovo pokra jeba te :lol:
Mozda je samo pozajmica :D
