If you have spent any time trying to farm progression in FH6, you already know how slow it can feel when the game is fighting you. That is why a lot of players keep circling back to methods built around FH6 Credits, especially when they want a cleaner way to turn skill points into something useful without wasting an evening in fr*e roam.
What players usually set up firstThe core idea is simple. Start with the Subaru 22B STI, then make sure the skill tree is fully unlocked. People like this car because it stays calm when you throw it sideways, and that matters more than top speed here. You are not chasing lap times. You are trying to keep a combo alive long enough for the points to stack up. A shared EventLab tune helps too. Most of the good ones are built for drift control, smoother transitions, and fewer random spins when the car is loaded with skill chain pressure.
How the run usually worksOnce the tune is on, load into a custom EventLab race that is known for farming. Before you start, match the recommended difficulty and keep assists from getting in the way. One small detail people talk about a lot is turning skill display off in the gameplay settings. Some players swear it makes the session behave better for point tracking. Maybe that sounds odd, but this kind of setup lives on little quirks like that. When the race begins, just keep the car moving in one long flow. Drift, link a few skills, avoid hard hits, and do not let the combo die. Most players aim for about four to five minutes per run.
Why this method feels so differentThe big appeal is the speed. In normal fr*e roam, you might spend ten or twenty minutes and walk away with almost nothing to show for it. In the EventLab loop, the same stretch of time can produce a far better return, especially if you stay clean and keep the car settled. That is where the Subaru really earns its place. It is not flashy. It just does the job. And for a grind like this, that is enough. You quickly notice that repeatability matters more than style, because one bad spin can wipe out the whole run.
What happens after the points landOnce the skill points are in, many players go straight back to the vehicle menu and spend them on Super Wheel Spin nodes. Then they jump right back into another run. That loop is the whole point: skill points in, rewards out, repeat. It is not exactly elegant, but it works, and that is why people keep sharing the same setup in forums and clips. The downside is obvious. If the game patches the odd tracking behavior this route leans on, the method could dry up fast. For now, though, it remains one of those tricks that feels too efficient to ignore, especially if you are trying to build up cheap buy FH6 Credits in u4gm while keeping the grind short.
U4GM Why Subaru 22B STI EventLab Drift Farm Works
