Blue Print 1.1
dujma
Blue Print 1.1
Post by dujma »
Jeli itko ovo instalirao. Ja sam zapeo na licenci! Zna li netko sta tocno treba??
pepi
Post by pepi »
sta je to?
ja na googglje naso samo c*ack
http://www.cracks.vg/cracks/BluePrint_1.1.4_15565.html
Dariolo
Post by Dariolo »
ako pitaš šta je Blue print to ti je ovaj programčić http://www.elektronika.ba/forum/viewtopic.php?t=4024 :lol:
pepi
Post by pepi »
ahaaaaa
a cim je nesto microsoft mos bacit
RIDIK
Post by RIDIK »
pa i ne e taka loso prvo da poglednes ;) ...
IQ500
Post by IQ500 »
ja nikako da uspijem to pokrenut, ubacim pravi HD serial, i kaze da onaj kljuc na valjda iako sam upisao ono u cmd sto se trazi
dujma
Post by dujma »
Meni nikako nece da se pokrene Actgen, stalno prijavi gresku i izbaci onaj prozor "Javi Microsoftu za gresku"!? Kako si ti odradio c*ack i licencu?
RIDIK
Post by RIDIK »
Install Notes:
Unzip, unrar, and install. Choose NOT to install a license during the installation process. After installation extract c*ack.ZIP; copy the patched EXE files to the program directory overwriting the existing files. Open LICENSE.DAT in a text editor and replace "deadbeef" with your HD Serial # (i.e. A1234567, do not include the "-" character). Save the file and from the command prompt run "actgen license.dat" and use the modified file to license the program. Place the license in the program directory or your default license location.
jas postapiv vaka i se e OK.
dujma
Post by dujma »
Ajde malo opisi sta si tocno napravio, jesli li mjenjao sve "deadbeef"-ove i sa kojim HD serial numberom. Od diska ili od Voluma na koji se instalira tj. particije!??
RIDIK
Post by RIDIK »
od diskot
RIDIK
Post by RIDIK »
posto gledam deka ve zaebava aj probajte so ovaa verzija :
http://rapidshare(dot)com/files/127229417/BluePrint.PCB.v1.8.0.336-TBE.part1.rar
http://rapidshare(dot)com/files/127231196/BluePrint.PCB.v1.8.0.336-TBE.part2.rar
BluePrint-PCB 1.8.0.336 | 178 MB
Automate the PCB documentation process, all while increasing its detail, streamlining distribution, and easing the entire process....PCB documentation is a critical part of the design chain as it defines the specifications on how an electronic product is to be built.
The more detailed the documentation the less likely manufacturing mistakes will occur. It also ensures that repeat builds of the same product are consistent and makes final inspection easier with less chance of unit rejection or shipment delay while waiting for assembly deviations to be approved.
