Evo PUNO materijala o spy bezicnim bubama
Muris
Схему и фотографии прислал администратор дружественного нам сайта из Боснии.
Радиус действия по заявлению автора 1км!Haha, da da, poslao sam i njemu slike. Evo sad sam mu poslao i ovaj fajl:
http://www.elektronika.ba/forum/uploadz ... _R0464.rar
Evo na ovom linku imate tehničku dokumentaciju o ruskim tranzistorima za zamenu istoimenih.
http://www.platan.ru/cgi-bin/qwery_td.p ... art=platan
Pazi sad ovo ja sam uspeo da je prevedem ali nece da me prepozna kao registrovanog clana cim se registrujem on me vraca na ruski jezik.Ima li neka fora da mogu da se registrujem i da mi ostane na engleskomtrax wrote:ta ruska moze, idi na google translatorili na av.com i uradi translate.
Pod "registrujem" sam podrazuevao prijavljivanje
Napokon sam nabavio super skener i radio stanicu Yaesu VX-3 sve u jednom.Evo slike uređaja.
Specification:
Frequency Ranges: RX 0.5-1.8 MHz (AM Broadcast)
1.8-30 MHz (SW Band)
30-76 MHz (50 MHz HAM)
76-108 MHz (FM)
108-137 MHz (Air Band)
137-174 MHz (144 MHz HAM)
174-222 MHz (VHF TV)
222-420 MHz (ACT1)
420-470 MHz (430 MHz HAM)
470-800(729) MHz (UHF TV)
(757-774) MHz (UHF TV)
800-999 MHz (GEN2; USA Cellular Blocked)
TX 140-173 MHz , 420-469 MHz
Channel Steps: 5/9/8.33/10/12.5/15/20/25/50/100 kHz
Frequency Stability: ±5 ppm (–10 °C to +60 °C)
Repeater Shift: ±600 kHz (144 MHz)
±1.6/5.0/7.6 MHz (430 MHz)
Emission Type: F2D , F3E
Antenna Impedance: 50 OHM
Supply Voltage: Nominal:3.7 V DC, Negative Ground
Operating: 3.5 ~ 7 V, Negative Ground (EXT DC Jack)
5.0 ~ 7 V, Negative Ground (EXT DC Jack with Charging)
Current Consumption: 120 mA (Receive)
60 mA (Standby, Saver Off)
30 mA (Standby, Saver On, Save Ratio 1:2)
50 mA (Radio Band Receive)
100 µA (Auto Power Off)
1.3 A (1.5 W Tx , 144 MHz) 3.7 V DC
1.6 A (3 W Tx , 144 MHz) 6 V DC
1.2 A (1 W Tx , 430 MHz) 3.7 V DC
1.8 A (2 W Tx , 430 MHz) 6 V DC
Operating Temperature: –20 °C to +60 °C
Case Size (W x H x D): 1.9” x 3.2” x 0.9” (47 x 81 x 23 mm)
(W/O knob & antenna)
Weight: 4.6 oz (130 g) With FNB-82LI & antenna
Transmitter RF Power Output: 1.5 W (@ 4.5 V AA x 3 or 3.7 V FNB-82LI 144 MHz)
3 W (@ 6 V or EXT DC 144 MHz)
1 W (@4.5 V AA x 3 or 3.7 V FNB-82LI 430 MHz)
2 W (@ 6 V or EXT DC 430 MHz)
Low 0.1 W (@ 4.5 V AA x 3 or 3.7 V FNB-82LI)
Low 0.3 W (@ 6 V or EXT DC)
Modulation Type: Variable Reactance F2D , F3E
Maximum Deviation: ±5 kHz (F2D , F3E)
Spurious Emission: At least 60 dB below (HIGH)
At least 50 dB below (LOW or less than 1 W)
Microphone Impedance: 2 k OhM[/img]
http://www.elektronika.ba/forum/uploadz ... u_VX-3.jpg
Specification:
76-108 MHz (FM)
222-420 MHz (ACT1)
Skener sam platio 220e a nasao sam ga preko oglasa http://www.radista.info/notices/index.htm ,a vidim da je lik od koga sam kupio skener stavio svoj bener na tom sajtu NESA TISA
Evo jos jedne stranice s teorijom o neizbjeznoj temi ovdje - bubama. Svi oni novi genijalci koji imaju bezbroj pitanja o bubama neka prvo procitaju sto ovdje pise
http://hr-elektronika.tripod.com/minipred.htm
Re: Evo PUNO materijala o spy bezicnim bubama
Zamene za ruske tranzistore!
Evo linka za zamene ruskih tranzistora i IC kola.
http://rapidshare(dot)com/files/230885985/r ... i.rar.html" onclick="window.open(this.href);return false;
Evo jedna super knliga o spy projektima i rešenjima.
http://narod.ru/disk/9430838000/101%20S ... s.pdf.html" onclick="window.open(this.href);return false;
101 Spy Gadgets for the Evil Genius
This book contains complete plans for a wide variety of spy gadgets, ranging from very basic projects to advanced projects that use the cutting edge of technology. Although each plan results in a working project, all of the plans in this book can be modified, mixed or matched to create many additional useful tools that can be used in the covert acquisition of "secret" information. The technology is presented in a way that allows the reader to build the projects using whatever pans are available, and although the plans may call for an exact part number, most of the technology used can be substituted for similar easy-to-find parts.
I hope that IOJ Spy Gadgets for the Evil Genius will help you expand your knowledge about many different types of technology, and how you can modify these technological principles for your own amusement and enjoyment
