To perform a fidget spinning dribble in FIFA 26 Coins, beginners should first become familiar with the basic skill move controls. The technique typically involves using the right stick to rotate the ball around the player in a circular motion. The exact input can vary depending on your console: on PlayStation, rotate the right stick clockwise or counterclockwise in combination with movement; on Xbox, use the equivalent rotation on the right stick. Practicing in training mode helps you get a feel for the speed and timing needed to execute the move smoothly.
Successful fidget spinning dribbles are not just about fast inputs-they also depend on timing and positioning. Avoid spinning when surrounded by defenders in all directions; instead, use the move when there is at least one clear exit path. The spin works best near the edges of the penalty box, around midfield, or when cutting inside from the wings. Timing your spin just as a defender approaches increases the chance of evading tackles and opening space for a pass or shot.
Advanced players often combine fidget spinning dribbles with other skill moves, such as stepovers, body feints, or quick direction changes. This combination makes your movements less predictable and more difficult to defend against. For example, spinning quickly to change direction, followed immediately by a buy FIFA 26 Coins sprint, can leave defenders off balance and create scoring opportunities. Experimenting with different sequences in training mode will help you discover combinations that suit your play style.
MMOexp:EA FC 26 Fidget Dribbling Guide
