USB/serial PIC programator
Sve vezano za mikrokontrolere
selec1
Post by selec1 »
evo...to sam ja radil
http://www.crowcroft.net/kitsrus/diypack22.zip
tu imate sve za skinut kaj vam treba za izradu...moj je model 149bc
znaci, skinite diypack22, instalirajte...tam di instalirate vam se pojavi folder unutra je .pdf file pod imenom k149bc...unutra su sheme za vise programera...tj vise modela...isto tak .HEX file koji treba za PIC na programerki
Shenda
Post by Shenda »
Ovo tvoje izgleda močno...
... samo, ja nikako da nađem taj .pdf file... a nema ga ni u .zip-u...
... pa mi nije baš najjasnije, jel' ja ne znam naći il' si ti nekaj za**bal...
imas ga u folderu gde ti je program instaliran...
selec1
Post by selec1 »
da...trebas skinut ono, onda otvorit rar i pokrenut exe file
kad se instalira onda tam nađeš pdf filei i tam sve pise o tome
Shenda
Post by Shenda »
... piše :!: :wink:
kasamiko
Post by kasamiko »
Where can i get the complete schematic and pcb layout of this programmer?
rhonnz
@kasamiko, you have to download and unzip the .zip file from the address mentioned above. Then you have to run the setup.exe file that will create a folder on C:\ disk. In that folder you will find .pdf files that contain all the information you need.
@selec1, gdje si nabavio FTDI chip i koliko si kilonjutna izbrojio za njega?
kasamiko
Post by kasamiko »
@Smjesko
Thanks make..i'll try it.. :wink:
i can't run the setup.exe on XP...
rhonnz
How come ? I can. Perhaps something is wrong with your Windows?!
ft232 imas u radio klubu za 230din
Koliko je to Eura ili kuna ?
oko 3 eura
Prilicno jeftino. Ja sam izradio programator koji ide na USB-port. Ima jedan PIC koji u sebi vec sadrzi USB sucelje. Ima jos nekih sitnica za izbrusiti prije slikanja i postavljanja ovdje.
Shenda
Post by Shenda »
PIC18F4450?
kasamiko
Post by kasamiko »
Smjesko wrote:How come ? I can. Perhaps something is wrong with your Windows?!
Extracted the whole archive...click the SETUP.EXE nothing happened...
rhonnz
selec1
Post by selec1 »
ovaj smd ft232 je narucen iz engleske...a dosel je u neku firmu u zg(ista firma iz koje je narucen) i onda je dosel u vz
neznam tocno kak se zove...to mi je prof narucil
a kosta 54 kn
@Shenda, PIC 18F2550 :!:
@Kasamiko, download this and unrar to your C:\ disk :!:
http://rapidshare.de/files/39577372/diypgmrp.rar.html
Shenda
Post by Shenda »
@ Smešni - daj shemu :!:
... a ja tebi avatar ...
http://www.elektronika.ba/forum/uploadz ... smiley.gif
Hvala za zutog Ja. :D
Shemu imas na www.sprut.de a programator se zove "USB brenner 8 mini P"
(ovo sam ti vec bio postao ali je post iz nekog razloga nestao - mozda to ima veze s moderatorima i pocetkom novog mjeseca :D, ili mozda punog mjeseca :lol: )
