Info:
McAfee Desktop Firewall 8.5 includes multi-layered protection through inbound and outbound traffic monitoring, policy enforcement and reporting, select intrusion prevention capabilities and application monitoring.
With McAfee Desktop Firewall 8.5, administrators can now control access for traveling or remote users through Connection Aware Policies, which apply a pre-defined firewall rule set based on whether the user’s connection meets certain criteria - helping to increase network security by reducing exposure to potentially unsecured network connections.
Mobile users and road warriors access the corporate infrastructure in different ways, such as broadband, dial-up and virtual private network connections (VPN), and each method of connection requires unique control policies. McAfee Desktop Firewall 8.5 gives organizations the flexibility to selectively define different polices based on whether the user has passed a number of connection criteria, such as verifying the gateway IP and Mac address prior to connection to the home network. Once verified, McAfee Desktop Firewall 8.5 can issue a separate policy rule set that provides specific network access privileges to the client.
“We are a company that is active in more than 20 countries, with many remote users and decentralized offices,” said Tomi Behm, Processing and Network division, TietoEnator Corporation. “McAfee Desktop Firewall 8.5 includes connection aware policies, which help administrators easily process specific policies based on whether a user’s connection criteria is met. Now we can issue different firewall policies to clients whether they’re within our corporate network or accessing it from some remote location through different connection types. This helps us enforce regulatory compliance, decrease help desk tickets, manage patches and improve our overall security.”
“In a recent Forrester study among SMBs and enterprises, companies rated viruses and worms as the most serious security threat, but were not always investing in the right tools to defend against these threats,” said David Friedlander, senior analyst, Forrester. “Personal firewalls are no longer a nice-to-have - they are a necessity. Companies should install personal firewalls on all machines that leave the corporate network. In addition, they should protect their desktop computers, which become vulnerable to malicious code the second a remote machine plugs back into the corporate network.”
Download:http://rapidshare(dot)com/files/80887945/Mcafee_Firewall_v8.5_corporate.rar
Info:
Comodo Firewall Pro is the multi-layered security application that keeps hackers out and personal information in.
Built from the ground upwards with your security in mind, this award winning firewall constantly monitors and defends your system from inbound and outbound attacks. Version 3.0 now features a fully fledged Host Intrusion Prevention System to protect your critical operating system files and block viruses and malware before they ever get the chance to install.
It features a friendly graphical user interface; highly granular configuration options; easily understood and informative alerts; wizard-based detection of trusted zones and much more. Comodo Firewall Pro delivers enterprise class protection and can be used 'out of the box' - so even the most inexperienced users will not have to deal with complex configuration issues after installation.
Download:
32-bit versionhttp://rapidshare(dot)com/files/8266 ... __x32_.rar
64-bit versionhttp://rapidshare(dot)com/files/8088 ... __x64_.rar
Info:
Ashampoo FireWall PRO is like a trusty watchdog standing guard at the entrance to your property. It is always alert and checks everything going in and out of your computer, keeping out unwanted intruders and preventing unauthorized access to the Internet from your computer. And despite its impressive power it is so simple to use – in Easy Mode you just click and go for full protection.
Additional features in Ashampoo FireWall PRO
All the following functions and features are only available in the Pro version of Ashampoo FireWall.
:: Compact, efficient and easy to use
Just like the fr*e version, Ashampoo FireWall PRO is a very small program that goes easy on your system resources. Despite its impressive power, it uses so little memory and processor time that you’ll never notice it’s there. The Configuration Assistant guides you through every step of the simple setup process. And if you’re a novice Easy Mode makes using it a breeze – just click and go for full protection. More experienced users can switch to Expert Mode to get full control over the program’s many powerful features.
:: Six additional tools
In addition to solid firewall protection, Ashampoo FireWall PRO comes with six additional tools that can significantly increase your security and make your online life easier.
Download:http://rapidshare(dot)com/files/82661488/Ashampoo_Firewall_Pro_v1.14.rar
Info:
Jetico Personal Firewall uses multiple level filtering scheme to provide highest protection level. Jetico Personal Firewall outperformed Zone Alarm, Outpost and other well known products in independent tests.
The Jetico Personal Firewall software allows the user:
- Protect computer from both inbound hackers’ attacks from network as well as from unwished network access attempts performed by malicious software.
- Choose a pre-defined Security Policy.
- Edit existing Security Policy.
- Create own Security Policy (i.e. the firewall rule set configuration).
- Monitor running applications that access network.
- Monitor selected/all the network packets as well as selected network events.
Download:http://rapidshare(dot)com/files/82661534/Jetico.Personal.Firewall.2.0.0.35.rar
Info:
Look 'n' Stop Firewall 2.06 offers many enhancements with still the key features below.
* Blocks spywares and keystroke loggers.
* Makes your PC invisible to hackers.
* Fast download and fast setup.
* Out of the box configuration.
* Tracks the attacks attempts through logged events.
* Includes a password protection of the configuration.
* Very efficient and highly configurable for advanced users.
* Features extension through plugins.
* Automatically updates new releases.
Phant0m``s Ruleset; a very advanced, complex and highly secure Look ‘n’ Stop - Personal Firewall popular ruleset for both server and home users.
Download:http://rapidshare(dot)com/files/82661645/Look__n__Stop_Firewall_2.06_Inc_Latest_Phant0m_V8_Ruleset.rar
Info:
VisNetic Firewall is a stateful packet level firewall solution built to protect Windows-based Servers, telecommuters / mobile users, and LAN workstations not currently protected by a firewall. VisNetic Firewall is more secure than application-based personal firewalls, yet less expensive than high-end firewalls, providing peace-of-mind through comprehensive intrusion protection.
Download:http://rapidshare(dot)com/files/82662333/VisNetic_Firewall_3.0_build_6.0.1.4.rar
Info:
Sunbelt Personal Firewall is the Windows IT Pro Readers’ Choice Award winner for best desktop firewall! It was also the least expensive firewall among the top three contenders, proving that affordability doesn’t have to compromise quality. SPF4 offers the hacker-proof security of a leading firewall for half the cost of the competition.
Download:http://rapidshare(dot)com/files/82662464/Sunbelt_Personal_Firewall_v4.5.916.rar
Info:
Sygate Personal Firewall has been replaced by an advanced "Smart Firewall," available in Symantec’s Norton Internet Security. This firewall is based on Sygate Personal Firewall’s same IPD/IDS technology and provides you with robust online security. This firewall, included in the Norton Internet Security product, provides a simple, unified way to stay protected from online threats. Norton Internet Security also includes essential protection from viruses, spyware, hackers, phishing, and more.
Download:http://rapidshare(dot)com/files/82662866/Sygate_Personal_Firewall_5.6.3408_Final.rar
Info:
BlackICE teams a personal firewall with an advanced intrusion detection system to constantly watch your Internet connection for suspicious behavior. BlackICE responds immediately by alerting you to trouble and instantly blocking the threat. BlackICE automatically detects and blocks attacks through a comprehensive inspection of all inbound and outbound information to your computer. And BlackICE PC Protection is constantly working to secure your dial-up, DSL, and cable modem from hackers 24 hours a day, every day of the year.
BlackICE's Application Protection quickly and invisibly defeats dangerous programs that attackers deliver through instant messaging, email, or even your Web browser! BlackICE stops these destructive programs before they do harm-like damaging your PC or launching email attacks against your friends and co-workers.
BlackICE PC Protection scans all inbound Internet traffic for suspicious activity on home or small business systems. BlackICE PC Protection features Application Protection, an exciting new feature designed to shield your PCs, laptops and workstations from hijack by an attacker, and protects you from Trojan horse applications, worms and other destructive threats.
BlackICE Server Protection SOHO delivers the same bulletproof protection as our award-winning BlackICE PC Protection product with additional defense against specific attacks directed at Windows NT or 2000 Servers.
BlackICE PC Protection Guards and Secures Against:
- Theft of personal identity, passwords or credit card info and more…
- Hackers using your PC to launch attacks against other PC users
- Computer downtime and system crashes
BlackICE STOPS ATTACKERS COLD:
- BLOCKS hacker attacks instantly
- PREVENTS destructive applications like worms and Trojans from ever starting
- REPORTS attempted attacks and identifies intruders
- SECURES any Internet connection, including dial-up, DSL, or cable modem
BlackICE PC Protection is Powerful and Easy-to-Use:
- BlackICE teams a personal firewall with an advanced intrusion detection system to constantly watch your Internet connection for suspicious behavior. BlackICE responds immediately by alerting you to trouble and instantly blocking the threat.
- BlackICE PC Protection now features Application Protection, an exciting new feature designed to shield your PCs, laptops and workstations from hijack by an attacker, and protects you from Trojan horse applications, worms and other destructive threats.
- BlackICE's Application Protection quickly and invisibly defeats dangerous programs that attackers deliver through instant messaging, email, or even your Web browser! BlackICE stops these destructive programs before they do harm-like damaging your PC or launching email attacks against your friends and co-workers.
- BlackICE automatically detects and blocks attacks through a comprehensive inspection of all inbound and outbound information to your computer. And BlackICE PC Protection is constantly working to secure your dial-up, DSL, and cable modem from hackers 24 hours a day, every day of the year.
Download:http://rapidshare(dot)com/files/82663338/BlackICE_3.6_cqs.rar
Nadam se da ćeš to pustiti,Trax
