Upravljanje steperom
enzo05
Post by enzo05 »
Pokusavam napisati kod za upravljanje steperom u mikroC-u, ali ne radi sve kako treba pa ako moze pomoc oko toga:
// LCD module connections
sbit LCD_RS at RB0_bit;
sbit LCD_EN at RB1_bit;
sbit LCD_D4 at RB4_bit;
sbit LCD_D5 at RB5_bit;
sbit LCD_D6 at RB6_bit;
sbit LCD_D7 at RB7_bit;
sbit LCD_RS_Direction at TRISB0_bit;
sbit LCD_EN_Direction at TRISB1_bit;
sbit LCD_D4_Direction at TRISB4_bit;
sbit LCD_D5_Direction at TRISB5_bit;
sbit LCD_D6_Direction at TRISB6_bit;
sbit LCD_D7_Direction at TRISB7_bit;
// End LCD module connections
char txt1[]="Running";
char txt2[]="Stopped";
void runMotor()
     TRISB = 0;
     PORTB = 0;
     Lcd_Init();                     // Initialize LCD
     Lcd_Cmd(_LCD_CLEAR);            // Clear LCD display
     Lcd_Cmd(_LCD_CURSOR_OFF);       // Turn cursor off
     Lcd_Out(1,1,txt1);
     CMCON = 0x07;     // To turn off comparators
     ADCON1 = 0x06;    // To turn off analog to digital converters
     TRISD = 0;        // PORT D as output port
     PORTD = 0x0F;
     do
       PORTD = 0b00000011;
       Delay_ms(100);
       PORTD = 0b00000110;
       Delay_ms(100);
       PORTD = 0b00001100;
       Delay_ms(100);
       PORTD = 0b00001001;
       Delay_ms(100);
     }while(1);
void stopMotor()
     TRISB = 0;
     PORTB = 0;
     Lcd_Out(1,1,txt2);
     PORTD = 0x0F;
     do
       PORTD = 0b00000000;
       Delay_ms(100);
       PORTD = 0b00000000;
       Delay_ms(100);
       PORTD = 0b00000000;
       Delay_ms(100);
       PORTD = 0b00000000;
       Delay_ms(100);
     }while(1);
void main()
     runMotor();
     TRISC.F0 = 1;
     TRISC.F1 = 1;
     while(1)
       if(Button(&PORTC,0,10,0))
         runMotor();
       if(Button(&PORTC,1,10,0))
         stopMotor();
Shema iz proteus-a:
http://i67.tinypic.com/t8qjbk.png
Kad pokrenem simulaciju, motor se pocne okretati, ali kad pritisnem taster za zaustavljanje nista se ne desava, motor se i dalje vrti nakon toga.
Maki
Re: Upravljanje steperom
Post by Maki »
Ovdije je problem.
do
PORTD = 0b00000011;
Delay_ms(100);
PORTD = 0b00000110;
Delay_ms(100);
PORTD = 0b00001100;
Delay_ms(100);
PORTD = 0b00001001;
Delay_ms(100);
}while(1);
Petlja će se izvršavat beskonačno, neće se vratiti u main.
Rješenje je unutar do-while petlje ubacit if da kad se stisne gumbić izađe iz petlje.
Npr.
do
PORTD = 0b00000011;
Delay_ms(100);
PORTD = 0b00000110;
Delay_ms(100);
PORTD = 0b00001100;
Delay_ms(100);
PORTD = 0b00001001;
Delay_ms(100);
if(tu staviš gum/tipkalo s kojim gasiš) break; //break prekida izvođenje trenutne petlje, u tvom slučaju do-while
}while(1);
Edit:
Onda ti stopmotor funkcija više ne treba.
