Hi.
Working this tester anywhere? I Build this circuit and not work charging.The hex file not including config bits.
Please help me! Discharge is working ok, and schematic is ok? If have you function this tester please send me you shematic and good hex files.
Sorry me English I am living on Slovakia.
Thanks
Smart battery tester and charger
Re: Smart battery tester and charger
Please, link the schematic...
sorry me create schematic i must add to rar image has been very large.
Thanks
Thanks
- layout original.rar
- (254.89 KiB) Downloaded 180 times
- Rezistor na zem.rar
- (32.19 KiB) Downloaded 180 times
- Schéma.rar
- (25.34 KiB) Downloaded 195 times
Sorry for the late reply, I was quite busy.
Unfortunately I'm not the author of this project, nor have I built it. So I probably can't offer you much help.
According to the comments on the project page that resistor between pin 1 and ground doesn't need to be installed. Just leave the empty pads (DO NOT SHORT THEM!).
Compare your and original schematic once again, also check the PCB with the magnifying glass for short circuits between the tracks. Check the voltages.
Which firmware have you used?
You should try to reprogram MCU and verify flash first with latest firmware , and then with the older versions.
Regards
Regards
